Z2U Common Beginner Mistakes to Avoid in Vellum
« Back To RCS WebinarsVellum may look straightforward when you first enter its colorful magical world, but its fast combat and roguelike progression can quickly become challenging. New players need to learn when to attack, when to reposition, and which upgrades actually support their current strategy.
Avoiding a few common mistakes can make those early runs much smoother.
Standing Still for Too Long
Combat in Vellum rewards movement.
Focusing entirely on dealing damage can make it easy to overlook incoming attacks or dangerous enemies approaching from another direction. Even when your build becomes powerful, good positioning remains important.
Try to develop the habit of attacking while regularly checking the battlefield around you. Staying mobile can create more opportunities to avoid unnecessary damage.
Choosing Upgrades Only by Their Immediate Power
A new upgrade may look impressive on its own, but that does not necessarily make it the best choice.
Think about how each option fits with your existing Spells and Powers. An upgrade that strengthens several parts of your current strategy can sometimes provide more long-term value than one powerful effect that operates independently.
This becomes increasingly important as your build develops.
Ignoring Dangerous Enemies
When several enemies appear together, attacking whatever is closest is not always the best strategy.
Some threats can create much bigger problems if they remain on the battlefield. Learning to recognize priority targets can make chaotic encounters easier to control.
As you gain experience, identifying which enemies require immediate attention should become faster and more natural.
Trying to Copy One Perfect Build
Build guides can help beginners understand the game, but following them too rigidly can become a problem.
Roguelikes are designed around adapting to the choices available during a particular run. If the exact upgrades you want do not appear, forcing the same strategy may leave you with an incomplete setup.
Learning why certain abilities work together is more valuable than memorizing one specific build.
If you have been watching Vellum guides before deciding whether to play, there are several ways to pick up the PC version. z2u.com is one marketplace where players can browse Vellum CD Keys, compare the listed options, and check whether a key matches their required activation region.
Forgetting That Failure Is Part of Progress
An unsuccessful run is not necessarily wasted time.
Each attempt gives you another opportunity to understand enemies, test abilities, and learn which decisions work well together. Even a weak build can provide useful information for future runs.
Instead of focusing entirely on completing every attempt, use your early games to experiment.
Learn the Systems at Your Own Pace
There is no need to understand every mechanic immediately.
Start by becoming comfortable with movement and combat. Then gradually pay more attention to Spells, Powers, enemy modifiers, and build interactions.
Vellum becomes easier to understand once these systems begin connecting naturally. Avoiding basic mistakes and experimenting regularly can help new players progress without turning every run into a search for the perfect strategy.
