Instant Roofer - Human Certified Instant Measure Reports
BITEC -  - StrongHold
CCS-OpenForBusiness-
Reworked.AI -  - May
TPO Love
December 8, 2008 at 11:39 p.m.
HailCat56
My all time favorite TPO failure. Would've been easier to temp w/o the coating or bentonite dumped all over it.
[IMG]http://i80.photobucket.com/albums/j175/Roberts406/Roofing/blowup1.jpg[/IMG]
[IMG]http://i80.photobucket.com/albums/j175/Roberts406/Roof>>>
December 18, 2008 at 4:14 p.m.
catwmnrulezzzz
You asked what makes the PWT Welder better than the Leister. I have worked with Leister for years. The biggest thing that stands out with the PWT welder, is that it will not weld if it is not at the right temperature. It will not weld if the generator>>>
December 18, 2008 at 3:18 p.m.
catwmnrulezzzz
Heat welders can be very touchy and extremely unpredictable if the person running it doesn't know what to look for. To be honest, There is a welder called a PWT Lazer, that shuts off if it is not at the right temperature, or if it is not getting enough>>>
December 18, 2008 at 2:32 p.m.
catwmnrulezzzz
I do a ton of TPO and PVC work and I have never seen something like that. It looks like a "Shatter" situation you would see on the old Trocal membranes, but I have never seen or heard of a similar situation on TPO. There is a coating that is awesome f>>>
December 18, 2008 at 4:08 a.m.
Ah ha......
The key word in my quote was "small". On something small, like egg was asking about, the price of membrane material is pretty much a moot point. 10 square, so what's another 30 or 40 bucks/square when the whole job is probably 10K or mor>>>
December 18, 2008 at 3:10 a.m.
Chipper
Mike, "Did I say that?"
Kind of...
"A 60 mil TPO, (Carlisle in my humble opinion) on a small roof, is likely going to give a customer a suitable lifespan. But when you could put 60 mil or 90 mil EPDM on a the same price, the TPO seems foolish to>>>
December 18, 2008 at 1:13 a.m.
LOL LOL, love your last line.
I'm sure a competitor will use that against me some day. Gotta get my reply.
I think I got it.... Yeah, but the ark was only built to float for a couple of months.>>>
December 17, 2008 at 4:36 p.m.
Lee Vittalone
When EPDM first came out or when first exposed to it, roofers were like (including myself) "this is a damn inner-tube, this is junk, this will never last" but it took hold and worked out after some issues. Then seam tapes came out and initially they fa>>>
December 17, 2008 at 12:15 a.m.
Jedd wrote: [quote]Mike, it was'nt so much problems during installation, it's cake to apply, fully adhered weld the seams with a robot, the unsupported on the kerbs is the only pain. No, like I said it is the concept, lack of structure maybe also>>>
December 16, 2008 at 9:59 p.m.
HailCat56
>Chasing leaks on it is a nightmare as I am sure you have experienced.
I love every minute of it!
Chasing leaks is probably as close to the perfect job that someone like me can have.
>The guy over our area actually said that they like the TPO because i>>>
December 16, 2008 at 7:11 p.m.
Firestone Ultraply 78 was the Cooley sheet. JM was made by CGT.
What problems did you see with the Firestone.
(I'll catch up later........... gotta go)>>>
December 16, 2008 at 6:59 p.m.
Jedd,
Which pvc's have you installed? We've had mixed results ranging from trocal, durolast and some CGT products that were miserable, Cooley sheets that have worked fairly well, Sarnafil has been very good, and in 27 years, I've never had a Fibertit>>>
December 16, 2008 at 5:35 p.m.
Chipper wrote: [quote]Mike H, In comparing TPO to EPDM applications, I was curious if you could actually install the 60 or 90 mil EPDm at or near the price of TPO as mentioned. It looks to me like Carlisle has priced the TPO to move. The only EPD>>>
December 16, 2008 at 5:22 p.m.
Chipper
Also addressing Jedd's article. What do you guys do to avoid the scenario where condensation can form on the underside of the membrane in mechanically attached systems? Are you using a vapor barrier over the deck? Are you staggering insulation joints>>>
December 16, 2008 at 4:54 p.m.
Chipper
Mike H, In comparing TPO to EPDM applications, I was curious if you could actually install the 60 or 90 mil EPDm at or near the price of TPO as mentioned. It looks to me like Carlisle has priced the TPO to move. The only EPDM I can get cheaper than TPO>>>
December 13, 2008 at 10:26 p.m.
Chipper
We've put a lot of TPO down. It's mostly owner driven. If I push TPO to be competitive, it's going to be 60 mil as suggested and I only use Carlisle. We've yet to have any major problems with Sure-Weld but I can see where it's going to take a litt>>>
WTI - Banner Ad - We Hire Potential. We Build Skill. (March 2026 Coffee Conversations)
Attic Breeze - Side Bar - Performance Matters
Wil-Mar -  - March2026
Lakeside Construction Fasteners -  Ad - T17 FastLok
