SRS -  Ad - SRS Delivers Supplies During Storm Season
Velux  ad Shine a New Light
Brava - PRO Portal -
Company Policy
April 4, 2009 at 9:24 a.m.
Miscreant
Company Policy
Start with a cage containing five monkeys. Inside the cage, hang a banana on a string and place a set of stairs under it. Before long, a monkey will go to the stairs and start to climb towards the banana. As soon as he touches the stairs, spray all of the other monkeys with cold water. After a while, another monkey makes an attempt with the same result; all the other monkeys are sprayed with cold water.
Pretty soon, when another monkey tries to climb the stairs, the other monkeys will try to prevent it. Now, put away the cold water. Remove one monkey from the cage and replace it with a new one. The new monkey sees the banana and wants to climb the stairs. To his surprise and horror, all of the other monkeys attack him. After another attempt and attack, he knows that if he tries to climb the stairs, he will be assaulted.
Next, remove another of the original five monkeys and replace it with a new one. The newcomer goes to the stairs and is attacked. The previous newcomer takes part in the punishment with enthusiasm! Likewise, replace a third original monkey with a new one, then a fourth, then the fifth. Every time the newest monkey takes to the stairs, he is attacked. Most of the monkeys that are beating him have no idea why they are not permitted to climb the stairs or why they are participating in the beating of the newest monkey.
After replacing all of the original monkeys, none of the remaining monkeys have ever been sprayed with cold water. Nevertheless, no monkey every again approaches the stairs to try for the banana. Why not? Because as far as they know that's the way it's always been done around here. And that, my friends, is how a company policy begins. >>>
April 4, 2009 at 11:04 p.m.
pgriz
So let's give some credit to bad memories, that allow us to forget the bad experiences, and try again.>>>
April 4, 2009 at 10:55 a.m.
Dr.ROOF
So Miss, you are an expert at beating the your monkey?>>>
IB Roof Systems - Banner - The State of Single Ply Roofing in Florida - Watch
HS Exit Advisors -  Ad - Who We Are
Hi-Peak - TalentSearch -
Roofing Alliance - Future of Roofing -
