We need a new question of the month.
« Back To Roofers TalkAny ideas.....Gerry?
How about the worst employee you ever hired?
NOVA had a military show on one showing how the airforce tested plane before actually flying them. They were held over a stationary place by a 50' tether on the nose so the wind wouldn't blow them backwards. On a treadmill, which btw, wouldn't rotate, the tether would need to be att he tail. Otherwise, the airflow from the props would allow them to take off without even moving a foot forward.
roofermann Said: Mythbusters did this, wont take off wings need air across them to generate lift. :laugh:
then they had a faulty test. Under propulsion power, it is impossible for the treadmill to match the speed of the wheels. The planes propulsion system exerts its force against the body of air surrounding the plane, not the treadmill.
Carried to the "Nth" degree, the treadmill would experience a massive and infinite accelleration to immesurable warp speed as it attempted to match the wheel speed, but alas, as long as the plane's wheel bearings hold out, it can't slow down the plane.
Mike H Said: If an airplane sat on a treadmill that turned in the opposite direction as the planes wheels, at the exact same speed as the planes wheels, would the plane be able to take off?This sounds like a good topic since it's up in the air. B):side:
Mythbusters did this, won't take off wings need air across them to generate lift. :laugh:
If an airplane sat on a treadmill that turned in the opposite direction as the plane's wheels, at the exact same speed as the plane's wheels, would the plane be able to take off?
:side:
Ditto! ;)
24 years in business and I'm keeping it the same. a 1 man repair business.
