TCS -  Ad - 10 Year Trends
OCS - OutdoorCoffeeShop
Hunter Panels  - Products
CCS-OpenForBusiness-
IKO -  - Dynasty
Flat roof question
August 10, 2008 at 11:03 p.m.
Brian
Anyone ever heard of a fully adheard ISO/TPO roof? Non ballasted 8 story 3500 square. Adheared ISO???? Never done it and never heard of it.>>>
March 28, 2011 at 7:28 a.m.
Mine are cutoff after a couple of sentences, and I'm really trying to do my homework on TPO ahh!
March 26, 2011 at 1:24 p.m.
jimAKAblue
Old School Said: Hey Steve, whats with the site now. Do we only get 2 lines and then get cut off? A lot of unfinished posts here!
Maybe he's cutting out all the blather.
March 22, 2011 at 10:13 p.m.
jjshaggy
i would say olybond or watertight both are rising foam iso adhesives. supposedly you can use on metal deck, but ive never done on metal deck. just on precast concrete. either a self adhering tpo, or glue down tpo would work, for qualities sake i'd go with glue has more of a proven track record, if that can be said about tpo.
March 22, 2011 at 7:30 p.m.
AEIRoofing
http://technicaldatabase.fsbp.com/productData/foamadhesivesforinsulation/
August 16, 2008 at 5:50 p.m.
johnw
Curved shape cant strip and a special patented knife with eight blades spaced 1/2 inch apart and fanned out in a matching curve.>>>
August 16, 2008 at 3:27 p.m.
Mr. Funny Guy LOL>>>
August 16, 2008 at 3:00 a.m.
johnw
Hot gets brittle when cold. With a properly sharpened instrument I can split a fully-adhered cap sheet right down to the finish ply sheets clean as a whistle. When it's cold. That's usually the temperature range when it's also windy and wet. Once y>>>
August 16, 2008 at 1:48 a.m.
builderr wrote: [quote]fully adhered polyiso to steel deck?.......with what? David
Olybond. Millenium. Insta-stik. HOT. All would work. I think most mfr's have discontinued any approval of hot mopped insulation to metal deck... ??? bu>>>
August 15, 2008 at 4:56 p.m.
builderr
in regards to the rigid insulation system, despite method/ manufacturer of actual roofing system..... I would assume that the building envelope engineers would be the ones specifying this detail.
Specifically, new construction details vs re-roof specific>>>
August 14, 2008 at 4:46 a.m.
Yes Jeff, you're hearing me right. Fully adhered happens all the time. Here's a link to Carlisle's TPO page. First words are ..."mechanically fastened and fully adhered...."
As for the heat deterioration on membranes, after watching all of the sy>>>
August 14, 2008 at 1:39 a.m.
OldNBroken
Heat sink is also known as thermal bridging. Boards and insulations have a very low thermal transfer rate. (hence why they are insulations, duh). Conversely metals have a very high thermal transfer rate (conductivity). Any time you mechanically fasten you>>>
August 13, 2008 at 11:14 p.m.
Brian
I've never seen the heat sink your talking about on TPO or PVC, only on EPDM. That doesnt mean it dont happen, just mean I never seen it. But your right, heat will speed up the aging of the material. Most TPO products are tested at some outrageous temp f>>>
August 13, 2008 at 10:23 p.m.
Ever noticed the first place to thaw on a frosty roof is directly over the fasteners?
That's because the heat transfers through the fastener faster than it transfers through the insulation.
First place to prematurely age on most membrane roofs is direc>>>
August 13, 2008 at 2:46 a.m.
Brian
It's 100% adhered. TPO/ISO. No ballast! And this is ok? I primarily use Firestone so that is most of my TPO knowledge but please tell me if this would be acceptable by any manufacturers specs.
Mike your knowledge on flat far supercedes mine so I wont ar>>>
August 13, 2008 at 2:34 a.m.
DMAN
Mike H wrote: [quote]Huh???
... and usually done to eliminate the heat sink created by fasteners.
can you expound on that? Sounds interesting. :)>>>
QXO - Banner Ad - Who is QXO? (on-demand)
Equipter - 4000 -
RCS UK -  Ad - Launch
