OCS - OutdoorCoffeeShop
Malco -  - Veto HVAC Kits
Worst nightmare of my career so far.
May 6, 2012 at 3:04 a.m.
Ripster
Welp, I came across a flat built up that had been leaking for years according to the owner. I took a look and noticed that the portion directly above the damaged drywall in her living room had been patched with a large amount of tar (about another 1 to 2 inches on top of the gravel) and was on the side where the scuppers were located which made me think the excess tar was damning the water flow from the rest of the roof to the scuppers and causing back flow to seep into the cracks and into the house. Turns out I was only partially right. I removed all of the excess tar and the original built up from (what should have been) the low side of the roof. I replace it with some peel and stick and tied it into the built up that hadn't been tampered with on the high side. The rain came that night and water poured into the house in the same spots it always had. Ugh! Anyway, I came running back to the place when the customer called and there was a huge lake of water centered right on top of the transition between the old built up and my brand new peel and stick, right in the center of the roof and off to one side. I determined that the roof had either been sagging in the middle over time with all that tar and gravel or the house had shifted back some on it's foundation and reversed the pitch of the roof. In either case I figured there was a couple of ways to fix it. Either tear the whole thing off down to the rafters and shim them under the decking to give it the proper pitch, replace the decking and re roof it again. Or, jack (what should be) the high side of the house up with bottle jacks to adjust the pitch (yeah right, lol.). Or, pretend the roof was made that way and the builders just forgot to put a drain in the right spot, then putting a scupper right where the deepest part of the pond is, running it down the wall, and into a gutter that directs it back to the back of the house. As it is now, the water never even makes it to where the scuppers are placed originally. One more thought was to carve a groove into the decking and rafters from the ponding water to the scuppers but that would also require removing my brand new (and expensive) peel and stick and quite a lot of work too. Any thoughts? If not I'm going with the denial plan and installing a new scupper. lol. ...I'll upload some pics later.
May 12, 2012 at 7:13 a.m.
spudder1
Go Hot
May 9, 2012 at 2:05 a.m.
nailer james
reroof the section thats leaking. fire up a kettle or torch that shit town.get some hot tar on that mo fo.
May 9, 2012 at 12:15 a.m.
I have to ask.... just what EXACTLY is this "Peel n stick" stuff ye speak of?
May 8, 2012 at 5:21 p.m.
the next time you run into a problem roof, ask here FIRST what the best thing to do. You will get rock solid advice here. thousands of years experience to draw from.
May 8, 2012 at 4:43 p.m.
prsroof
shinglers with peel and stick with np1 caulk have no business on a flat roof
May 7, 2012 at 10:35 p.m.
Ripster
Thanks Old School, Copper! I checked out the "tapered" site! I'll probably use that soon on all this customers neighbors that have the same problem in their matching covenant homes! For now though on this one (due to a lack of funding and her insurance company refusing coverage) I just installed the new scupper like I had mentioned and sealed the seams of my peel and stick with NP1 and it works like a charm. The customer says it's the first time she's had no leaks in 7 years, 5 thousand dollars and 3 other roofers before me. ;) My ego is restored. lol. I was going to get a pic of the final outcome but my phone died right then. I'll throw one up later if I can. It came out pretty nice though.
May 6, 2012 at 6:30 a.m.
Why not use tapered insulation to push the water to where you want it to go. Of coarse that means re-roofing it. http://www.atlasroofing.com/general2.php?section_url=82
Versico - Banner - ReRoof Rapidlock V2
3M -  - Smog reducing
