SPRI  Ad - DORA Directory
NFRC - - Weather the Storm
Reworked.AI -  - May
08 days 05 hours 31 minutes 24 seconds
Question on flat roof......
October 28, 2008 at 3:50 a.m.
manbearpig
I have a roof that just needs a small patch about 24" x 12". The problem is I dont think this roof is EPDM rubber, so therefore I dont know if I can use the same materials I use to patch rubber roofs.
This roof is a 2/12, probably 35-40 years old....bu>>>
October 29, 2008 at 11:15 p.m.
Ralph
when you said the "roof" was 35-40 years old did you mean the roof or the house? Because if you meant the house, then you have a 15-20, maybe 25 year old shingled roof, covered by the newer product which would be 10-20 years old. I still put my money o>>>
October 29, 2008 at 6:53 p.m.
manbearpig
Sorry I havnt replied quicker. I will try to get a picture. Man......I just dont know very much about flat roofs. This roof dont look like a torch down....because I dont see where it has leaked out at edges...and when I look under the laps that are loose,>>>
October 28, 2008 at 12:42 p.m.
Could be a PIB in asphalt. That appears rubbery and gets hard. If it is, it is not as old as you say. Use roof cement, but tell them it's time for a new roof, and they should not expect too much from the repair.>>>
October 28, 2008 at 11:52 a.m.
A-T-T
That's what I thought but I assume Randy knows what Modified Bitumen is.>>>
October 28, 2008 at 11:45 a.m.
Ralph
[quote]The material looks to be about 3/16" thick, is very hard like tire rubber. It is in 36" wide rolls
It sounds like a smooth surface APP torch down to me.>>>
October 28, 2008 at 10:34 a.m.
A-T-T
A Picture would really help.>>>
SRS - Banner Ad - IRE 2027
Brava - PRO Portal -
